Activity Forums Maxon Cinema 4D Texturing Extruded Spline
  • Texturing Extruded Spline
    Posted by Stephen Turcotte on May 3, 2012 at 8:27 pm
    I’m working on modeling a trailer- it’s basically an extruded spline at the moment. Ideally I would like to displace all of the faces so it looks like a corrugated metal surface, but I’ve run into problems on the CAPS side. There are lots of triangles, which don’t make for a successful displacement.
    Does anyone know how to get the CAPS side to contain only Quads? Or should I be modeling this a different way?
    Thanks.
    Stephen Turcotte replied 14 years, 4 months ago 2 Members · 2 Replies
  • Brian Jones
    May 4, 2012 at 2:38 am
    if you make the caps of your extrude Quadrangles, check off Regular Grid and make the grid size fairly large so the number of triangles at the edges is fairly small (and let your Hypernurb do the rest) then use Subpoly-displacement it should give you a good corrugation.
    4078_corrugationtest.c4d.zip
  • Stephen Turcotte
    May 4, 2012 at 12:12 pm
    Thanks for the info/ example scene file. It worked perfectly, big help!
