Activity Forums Maxon Cinema 4D Textures Slipping on Objects
  • Textures Slipping on Objects
    Posted by R. Christopher Biggs on September 29, 2020 at 5:15 pm
    I’ve got a problem, I’ve got a primitive tube that when animated the texture slides around on it,
    read about the spline thing, but this is a C4Dr20 primitive its scaled in y (x6), animated thru nulls.
    2 textures on it one is a base metal look, the other looks like blood streaked it (this is the one thats moving)
    I’m a bit of a newbie, so any suggestions are welcome
    Andy Kiernan replied 5 years, 10 months ago 2 Members · 1 Reply
  • Andy Kiernan
    September 29, 2020 at 7:06 pm
    If the ‘blood streaks’ are created using a noise in a texture channel, then it’s possible that the noise is in world space, so the object is moving through it. Find the noise and change it to local/object space and it might fix it.
    Or try out different mappings on the material tag
