Activity Forums Maxon Cinema 4D Textures from Poly Haven
  • Textures from Poly Haven
    Posted by Andy Bryan on July 4, 2022 at 12:37 pm
    Hi all,
    I’ve downloaded from texture files from Poly Haven:
    https://polyhaven.com/
    And the textures are looking pretty good, but I’m just wondering if I’m using the right images in the right channels.
    I’ll use this one as an example:
    https://polyhaven.com/a/aerial_rocks_02
    These are the files downloaded and which channel I use them in. Please let me know if I’m right or wrong, and where, if anywhere, the leftover files should go.
    AO – In the diffusion channel.
    ARM (AO/Rough/Metal) – Not sure where this one goes.
    Diffuse – Confusingly goes in the colour channel according to an old video I watched.
    Displacement – Displacement channel.
    Normal (DX) and Normal (GL) – I opted for the GL in the Normal channel.
    Rough – Bump map channel.
    Rough AO – Reflection channel.
    I might be way off. Any advice please?
    Thanks.
    Andy Bryan replied 4 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
