Activity › Forums › Maxon Cinema 4D › texture turns off for no apparent reason
Posted by Jon Simpson on November 15, 2015 at 4:41 pmI have a short 100 frame animation where the texture on one object turns off and back on in two frames, 62 and 89. Absolutely no apparent reason for this. What should I be looking for that would cause this?
Jon Simpson replied 10 years, 10 months ago 2 Members · 6 Replies -
Brian Jones
November 15, 2015 at 5:41 pmthe two easiest thoughts are: you have duplicated geometry in the object or the texture is keyframed to turn off – that’s probably not the only two possibilities, it would help to see the scene file.
Jon Simpson
November 15, 2015 at 5:56 pmThanks Brian, here is the scene file and you will maybe have to add the .lib4d file to your browser
https://www.dropbox.com/s/0lr8vfawwm7c28d/C4Depot%20Real%20Earth%201.0.rar?dl=0
Brian Jones
November 15, 2015 at 6:36 pmonly seeing clouds but there are a bunch of missing pictures
static map with dots.png (Mat.3)
map marker animation_00336.png (Mat)
G:\Cinema 4D assets\USFLAG.TGA (usflag)
G:\Cinema 4D assets\WMCLM.TGA (column)
G:\Cinema 4D assets\WMCLMT.TGA (top)
G:\Cinema 4D assets\Tour_eiffel\tex\texture.jpg (texture eifel)
G:\Cinema 4D assets\Tour_eiffel\tex\alfa.jpg (texture eiffel)try a Save Project With Assets…
Jon Simpson
November 16, 2015 at 7:47 pmSorry about that. The only image that matters is this one: https://www.dropbox.com/s/epmc5smawgjevx8/culture%20cloud%20globe%20great%20lakes.png?dl=0
This is the one that shuts off
Brian Jones
November 17, 2015 at 4:06 amthe file I have does not use an image with that name – the one material that looks like it contains the image (based on the thumbnails) uses an image called ‘static map with dots.png’ – I tried using that for the image’s name and I get the planet with texture and I do see image drop in frame 71 and 75. That stops if I deactivate the Earth sphere and leave just the Earth Preview…
hard to tell what’s happening there as the Earth sphere has the second material with the texture “map marker animation_00336.png” missing… …and if I turn off earth preview Earth renders differently although the same material appears to be applied the same way…unless something prevents it I’d just disable Earth and go with the Earth Preview but I don’t know what the missing texture files are doing.
Jon Simpson
November 18, 2015 at 1:11 pmHey Brian, sorry for the late reply, I really appreciate you looking into this. Here is the missing image, I forgot I had replaced it:
https://www.dropbox.com/s/7qfeu40w3kl77ya/static%20map%20with%20dots.png?dl=0
