Activity Forums Zaxwerks Texture quality flickering
  • Texture quality flickering
    Posted by Boddaker on November 6, 2007 at 11:19 pm
    Hi, I am having trouble when rendering out an animation in AE CS3 with ProAnimator 4.3.2. I have a basic 3D text layer, and the standard gold reflection texture applied. Upon rendering the animation at best quality, I get random frames of draft quality on the text. Resolution is standard DV 720×480. Any idea what could be causing this?
    Here’s a test wmv: https://www.engelads.com/publicfiles/Zaxwerks/Flickers.wmv
    Any help would be appreciated!
    -Brian
    Serge Hamad replied 18 years, 9 months ago 3 Members · 3 Replies
  • Matt Rhodes
    November 7, 2007 at 4:01 pm
    Hi Brian.
    A few questions:
    1. Are you on the Mac or Windows?
    2. How do you render? On a single machine with “Make Movie”? Across multiple machines?
    It looks like the reflection map is getting lost at certain frames.
    m
  • Boddaker
    November 7, 2007 at 6:09 pm
    Hi Matt,
    I am on Windows XP 64bit edition, just rendering on this machine (quad core cpu, 4Gb ram).
    I’m going to do some more tests to see if I can narrow it down.
    -Brian
  • Serge Hamad
    November 20, 2007 at 8:47 am
    I think that the “Render Multiple Frames Simultaneously” feature in AE CS3 has to be disabled to eliminate your issue.
    Matt, could you confirm?
    Salut,
    Serge
