Activity › Forums › Maxon Cinema 4D › texture problems with symmetry
  • texture problems with symmetry
    Posted by Caspar Stracke on May 23, 2011 at 3:56 pm
    Hey Guys,
    Simple question on Symmetry:
    I loft-nurbed an amorphous body, used the Symmetry object and the shape perfectly welds itself together, seamless.
    But wen I now apply a texture -as simple as just a color w/ a small specular highlight- the seam is clearly visible.
    Under spotlight, it looks like two different shades of the color.
    Checked on and off “Weld Points”, played with Tolerance levels – no change.
    Anybody had this problem before?
    Any help MUCH appreciated,
    cheers,
    Caspar
    Caspar Stracke replied 15 years, 4 months ago 2 Members · 2 Replies
  • Randy Johnson
    May 24, 2011 at 7:05 am
    If you have not made the symmetry object editable the welding will only place the points over each other. If the object is editable then you have a single mesh and texture should be good to go.
    /Randy
  • Caspar Stracke
    May 24, 2011 at 1:19 pm
    Thank you Randy. That was the problem!
    C.C.
