Activity Forums Maxon Cinema 4D Texture Problem
  • Texture Problem
    Posted by Christian Remde on April 30, 2007 at 2:28 pm
    I’m trying to put a stone texture on text and I’m having a problem…
    In order for the texture to look good, I need to use the “Frontal” projection mode, but when I move the text or the camera, the texture doesn’t stick to the text…how can I get the texture to stay on?
    Christian
    Christian Remde
    https://www.christianremde.com
    Adam Trachtenberg replied 19 years, 4 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    April 30, 2007 at 2:59 pm
    You could bake the texture to your object, but you really don’t want to use frontal mapping in this case. You should use flat mapping or UVW mapping to lock the texture to the object.
    With NURBS objects, you can apply separate materials to each cap and to each bevel/fillet by typing the following abbreviations into the material tag’s “selection” box:
    C1 = Start Cap (Cap 1)
    C2 = End Cap (Cap 2)
    R1 = Start Rounding (Rounding 1)
    R2 = End Rounding (Rounding 2)
    If you are using deformers on the text, you’ll also want to give the text object a “Stick Texture” tag, which prevents the material from stretching when the object is deformed.
  • Christian Remde
    April 30, 2007 at 3:55 pm
    I’ll give that a try…thanks!
    Christian
    Christian Remde
  • Adam Trachtenberg
    April 30, 2007 at 4:30 pm
    One correction: I should have said the stick texture tag *allows* the material to stretch when the object is deformed (otherwise the texture slips).
