Activity › Forums › Maxon Cinema 4D › Texture Problem
Texture Problem
Posted by Joel Schären on March 18, 2020 at 3:27 pmDoes anyone know why the preview is right but the Texture on the Model isn’t?
Brian Jones replied 6 years, 6 months ago 2 Members · 3 Replies -
Brian Jones
March 18, 2020 at 9:41 pmthe texture preview is on a sphere with proper UVs at default mapping for the preview object (sphere in this case) but the render preview depends on the settings of the Texture tag so without seeing those settings I can only say ‘it can be different’. Also, if you do an actual render the result can be different again (though not usually with image textures like this one).
Joel Schären
March 19, 2020 at 8:44 amThanks for answering ☺
It’s also wrong in the render, that I checked, so I am really lost right now.
Brian Jones
March 19, 2020 at 4:14 pmso default texture tag settings, I see the problem now though, the texture is square (well, close) and a texture that goes on a sphere should be twice as wide as it is tall. Your texture is 1×1 not 2×1- since the texture is repeating you could just set Tiles U in the texture tag to 2
