Activity Forums Maxon Cinema 4D Texture Mapping
  • Texture Mapping
    Posted by Dave Montague on April 10, 2009 at 9:11 pm
    Can you turn on or off a shape or blend out a shape over time? For example: a chess piece on a chess board…have it fade out over a few seconds and then fade in?
    Thank you!!!
    Dave
    Dave Montague replied 17 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    April 11, 2009 at 3:30 am
    you can either use a Display Tag and check off Use Visibility and animate the visibility parameter or animate the transparency or alpha channel in your objects material
  • Dave Montague
    April 11, 2009 at 5:13 pm
    Thank you! That was so easy I feel like a spaz for asking.
