Activity Forums Zaxwerks Texture map question
  • Texture map question
    Posted by David Eells on January 18, 2007 at 9:00 pm
    Haven’t used Invigorator in a while and I’m running into an issue with texture mapping.
    I have an image of Florida, and I need to zoom in fairly close, at which point the outline of a county draws on. If I open the Florida vector file (512×548 pixels) in Photoshop and use it as a texture map, it ends up getting scaled and looking very soft.
    If I use a much bigger file, Invigorator scales it way down, and then when I zoom in it gets soft again. I thought I could get around this by using the Stroke effect and stroking a mask, but no luck.
    Any advice?
    Serge Hamad replied 19 years, 8 months ago 2 Members · 1 Reply
  • Serge Hamad
    January 19, 2007 at 1:16 am
    First, your texture map must have the same aspect ratio then your object.
    Second, create your map at the maximal resolution.
    For example if your object aspect ratio is 2:1, create a map that is 4000 x 2000.
    Keep in mind that the maximal resolution a map can have in order to work with Invigorator is 4000 x 4000.
    Salut.
    Serge
    “InvigoMany” On sale here:https://www.nyc-visual.com
