Activity › Forums › Zaxwerks › texture map proanimator
  • texture map proanimator
    Posted by Steve Hines on November 25, 2011 at 6:15 pm
    having trouble using texture map specifically sizing..when I bring in psd file the size doesn’t match the 3d object..am I saving the psd incorrectly..using proanimator vers 4.3.1
    or direct me to this subject here if already and I assume so, answered
    thanks
    Edward Wu replied 14 years, 10 months ago 2 Members · 1 Reply
  • Edward Wu
    November 25, 2011 at 7:14 pm
    Hi Steve,
    Be sure to crop the Photoshop document so that there are no margins around your image. This means, you will need to crop the top, bottom, left and right to the edges of your image. If your texture map has margins, then the map will not match the Illustrator outlines.
    Hope this helps.
    Best,
    Edward
