Activity › Forums › Maxon Cinema 4D › Texture keeps moving in animation
  • Texture keeps moving in animation
    Posted by Kale Collins on August 5, 2018 at 7:00 pm
    I have Two Objects with the same textures applied, and also the same texture for the Floor.
    When completed rendering the Animation, textures are shown jumping around.
    I would like for the texture to not move at all.
    anyone know how to turn off this feature? ☺
    Cheers !!~
    Emir Bojorquez replied 8 years, 1 month ago 2 Members · 2 Replies
  • Kale Collins
    August 5, 2018 at 7:08 pm
    12610_minirigidhoops0031.c4d.zip.zip
    Here is my file!
  • Emir Bojorquez
    August 5, 2018 at 11:46 pm
    That “flickering ” on the reflection is caused by the roughness, the only way to fix that, inside cinema, is to put your render settings really high, but that will increase your render time a lot.
    You should try to render passes, and then, using a compositor like After effects, you could blur your reflections.
    Good Luck
    Imagination is the best tool…
