Activity Forums Maxon Cinema 4D Texture issue
  • Texture issue
    Posted by Antonio Petit on April 17, 2015 at 10:46 pm
    Hello, i am new in the group.
    Maybe is a newbie question but this is !!#$¡ out 🙂 . i have a Barril and i have 2 textures.
    1) Brown color in diffuse layer and vertical wood in bump for texture ( this is because i want to change my main material to any color next.
    2) Label ( mix texture )
    Inside the ( 1 ) i have a bump material ( wood ) but i cant see in my viewport, i now is a sub material but, there is a way to see in ¨Tag ¨ projection and moving separately from the main color?.
    Thanks so much in advance.
    Antonio Petit Cwirko
    Creative art Director
    https://www.behance.net/antoniopetit
    Brian Jones replied 11 years, 5 months ago 2 Members · 3 Replies
  • Brian Jones
    April 19, 2015 at 5:47 pm
    if you used an Alpha channel in the Label material instead of Mixing you would be able to see the wood underneath it.
  • Antonio Petit
    April 19, 2015 at 7:15 pm
    Thanks for reply, yes but how can i control this submaterial by separate using a “cubic projection tag”?.
  • Brian Jones
    April 19, 2015 at 7:24 pm
    you can move the texture around using the Offset and Length settings in the tag or using Texture Mode then using the Move/Scale/Rotation tools.
