Activity › Forums › Zaxwerks › Texture Interaction With Fragments
  • Texture Interaction With Fragments
    Posted by Thomas Haight on November 3, 2013 at 11:43 pm
    Attached is a file that shows a problem that I am having rendering a project that uses fragmentation. I have rendered outlines imported from Adobe Illustrator using the stand alone version of ProAnimator 7. When the fragmentation segment is complete, there are patterns on the surface of the object that look like some kind of interaction with the fragments. I am unable to find anything in the documentation that helps me understand what is going on and how I can correct it. Any idea why this is happening?
    Edward Wu replied 12 years, 10 months ago 2 Members · 1 Reply
  • Edward Wu
    November 4, 2013 at 8:39 pm
    Hi Thomas,
    Normally, lines only show up if you are working with a transparent material. If you are working with a non-transparent material, you should not see any of the lines from the fragmentation. From your screen shot, it doesn’t appear that you are using a transparent material. Can you send the project file to me so I can take a look at your setup?
    My email address is ed@zaxwerks.com
    Best,
    Edward
