Activity › Forums › Maxon Cinema 4D › Texture fix?
  • Texture fix?
    Posted by Davor Kampel on February 14, 2014 at 6:28 am
    Hi guys. I am attaching a few screenshots of my scene. Is there an easy way to resolve the texture being distorted on the hat like that – without the UV maping process? (it’s an imported 3ds model and I’m not sure how to UV map it, for some reason the regular options for mapping don’t appear) I tryed playing with the settings but nothing seems to work quite perfectly..
    Brian Jones replied 12 years, 7 months ago 4 Members · 3 Replies
  • Adam Trachtenberg
    February 14, 2014 at 4:36 pm
    No, no easy fix unfortunately. It requires some fairly sophisticated UV editing to get that looking right.
  • Darby Edelen
    February 15, 2014 at 5:48 am
    A funky alternative that might work for you would be to use the two texture setups and alpha blend between them. This would give you a noticeable seam but that could be minimized.
    UV mapping would definitely be preferred.
    Darby Edelen
  • Brian Jones
    February 15, 2014 at 4:19 pm
    it might be possible to hide the seam under the blue band.
