Activity › Forums › Maxon Cinema 4D › Texture Control
  • Texture Control
    Posted by Chris Voelz on July 19, 2013 at 3:53 pm
    I am in the learning process and don’t know my way completely around cinema 4d R13. Hopefully you guys can help. I have a model that I am texturing, and I can do that fine. My problem is that I am trying to move and rotate the texture. I know how to use the texture axis mode, but for some reason I can not view the controls on my model. Normally you get a plane that you can see in your working area, but I can not see it. So it is making it hard to get the texture in the correct orientation. I think Cinema 4d called it the “texture envelope”. I have tried searching for this, but have not had luck. Hopefully it is an option somewhere that has been unchecked.
    Chris Voelz replied 13 years, 2 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    July 19, 2013 at 4:09 pm
    Make sure both the texture tag AND the object are selected.
  • Chris Voelz
    July 19, 2013 at 4:15 pm
    Awesome! Thank you Adam!
