Activity Forums Maxon Cinema 4D Texture change direction
  • Texture change direction
    Posted by Ben Fallin on July 17, 2008 at 4:37 pm
    I have some texture that is going vertically and I need to change it to horizontally. I’ve tried adjusting the angles as well as mirroring it horizontally but nothing seems to work.
    Adam Trachtenberg replied 18 years, 2 months ago 3 Members · 2 Replies
  • Brian Jones
    July 17, 2008 at 5:04 pm
    click on the texture tag set the Projection to something other than UVW – (Cylindrical?) and use the Texture Tool and rotate the texture or if this is an image you could also rotate the image in PShop (or whatever) before import
  • Adam Trachtenberg
    July 19, 2008 at 4:17 am
    Another option is to put the bitmap in a layer shader, add an effect>transform layer, and rotate in there.
