Activity Forums Maxon Cinema 4D Texture behaving weired
  • Texture behaving weired
    Posted by Chris Craig on August 6, 2016 at 10:11 pm
    Hi all
    I have imported an obj file and had set the preferences to vertices to fix a number of issues i was having with the model not being smooth. I have now textured the object and it appears that there is something weird going on and i dont know how to fix it.
    The circular element in this image is a C4D disc, so it is reflecting correctly…but everything else is not.
    Thanks for any assistance
    Chris Craig replied 10 years, 1 month ago 2 Members · 5 Replies
  • Chris Craig
    August 7, 2016 at 9:26 am
    Im working with C4D R17 and have asked a friend to take a look with his version. He is on R15 and the problem does not occur for him when he opens my project.
    Would anyone know what this could suggest?
    Thanks a lot
  • Adam Trachtenberg
    August 7, 2016 at 1:51 pm
    That’s odd. Are you using the physical renderer? If so does it also happen with the standard renderer? If you can post the file or .obj I’d be happy to take a look.
  • Chris Craig
    August 8, 2016 at 12:12 pm
    Hi Adam
    Yes, I am using just the physical renderer
    Here is just the bit with the issue. As mentioned, R15 works fine with this model.
    https://dl.dropboxusercontent.com/u/8505987/Model.zip
  • Adam Trachtenberg
    August 8, 2016 at 2:17 pm
    Click on the Normals Tag and then click the “Align Vertex to Face Normals” button. Should do the trick although I’m not sure why it didn’t come in correctly.
  • Chris Craig
    August 8, 2016 at 10:17 pm
    Thank you Adam. That has done the trick.
    I really appreciate not just this help, but each and every time you give me advice.
    Thanks so much.
