Activity › Forums › Adobe After Effects › textual landscape
  • textual landscape
    Posted by Vincent Lablee on November 9, 2015 at 10:25 am
    hei,
    i’m looking for advice to construct a form of “textscape” or textual landscape in adobe after effects cc, on one channel/screen. i’d like it to be “moving” or in “motion” in a “geological” form/mass of landscape. ill add references below.
    does anybody have any good tutorials to create a similar structure of text?
    https://www.youtube.com/watch?v=5RNHEUJzVzU (see first 7 seconds and 0:29 – 0:33)
    https://www.youtube.com/watch?v=drvJQmdkL_s (from 12 seconds in)
    thanks
    Chris Bobotis replied 10 years, 10 months ago 3 Members · 6 Replies
  • John Cuevas
    November 9, 2015 at 2:27 pm
    I think there are a few methods that could get you those results. For plugins, Trapcode Form, and Mettle Shapeshifter both could produce those results.
    If you want to stay within AE, I you would want to precomp some type white/black map and then use the distort – displacement map effect, maybe in combination with some other of the distort effects(bezier warp, mesh warp, bulge).
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Chris Bobotis
    November 9, 2015 at 2:53 pm
    FreeForm Pro would be perfect for this.
    Very easy to pull this effect off and very fast to render. See: https://www.mettle.com/product/freeform-pro/
    Come to think of it, I will add this to my list of tutorials for FreeForm pro. Thanks, great idea for a use of FreeForm Pro 🙂
    Cheers,
    Chris
    mettle.com
  • John Cuevas
    November 9, 2015 at 5:11 pm
    Yeah, that’s what I meant, Freeform Pro, not shapeshifter.
    ThinkCK
  • Chris Bobotis
    November 9, 2015 at 6:26 pm
    Here is a quick set-up of a Textual Landscape using FreeForm Pro in After Effects (see attached png):
    9437_textterrianfreeformpro.png.zip
    Cheers,
    Chris
    mettle.com
  • Chris Bobotis
    November 9, 2015 at 6:29 pm
    And here it is again (inline):
    Cheers,
    Chris
    mettle.com
  • Chris Bobotis
    November 9, 2015 at 7:21 pm
    And here is the project file (see attached)… as I mentioned earlier… quick & dirty… needs love but a good start nonetheless 🙂
    9438_ffprotextuallandscape.aep.zip
    Cheers,
    Chris
    mettle.com
