Activity Forums Adobe After Effects Expressions TextDocument object’s “Leading” Property?
  • TextDocument object’s “Leading” Property?
    Posted by Andy Kreutzberg on May 8, 2013 at 3:05 pm
    Hello all,
    this is probably an easy scripting thing but i can’t get this one to work no matter what i tried:
    In a script, all parameters for characters in a text layer seem to be adjustable by the TextDocument object, except the Leading parameter. This parameter is not listed in the AE scripting guide. But why? And how can i change this value with a script?
    I tried this:
    textDocument2.leading = 40;
    which just returns “auto” inside of after effects, no matter what value i give it, but at the same time it does not seem to fail to recognise the property because the script continues after this line.
    Is there a dependancy on another value maybe or am i just using the wrong property? All other values (font size, tracking, etc) work as they should.
    Todd Kopriva replied 13 years, 3 months ago 3 Members · 2 Replies
  • Dan Ebberts
    May 8, 2013 at 3:11 pm
    Leading is not accessible to scripting. The fact that your script continues without error probably just means that it has appeneded its own, non-functional leading attribute to your textDocument2 object (just a guess).
    Dan
  • Todd Kopriva
    May 8, 2013 at 3:58 pm
    If you want leading access in scripting, you should submit a feature request:
    https://www.adobe.com/go/wish
    After Effects team blog
