Activity Forums Apple Final Cut Pro Legacy Text/Crawl Problems – with DVD authoring
  • Text/Crawl Problems – with DVD authoring
    Posted by Xtothed on February 14, 2006 at 9:41 am
    Hi All,
    Have seen similar posts below, but no definitive answer…so hoping someone might be able to help.
    Have created 30 second graphic animation, with text crawling at bottom of screen – this is looks perfect in After Effects and FCP, and when I dump this to Beta tape.
    But when I export this from FCP as a self-contained-movie (Uncompressed 8 bit) into either iDVD or DVDSP, the text crawling at the bottom is massively unreadable (really blurred and little jerky). No matter how I export the movie, when I burn it to video DVD it looks rubbish.
    I have also tried exporting via compressor and then creating the DVD in DVDSP. This way, the text is less blurred but instead there is glitching over the letters, as if I have exported it using a compressed codec – which I havent. I have also tried playing a Beta Tape of this animation straight into a DVD Recorder – again the text is less blurry but the glitching still occurs.
    Can anyone help? This is causing me a massive headache!! I will also post this in the DVDSP forum, if it could be the encoding of the final movie.
    Cheers
    Xavier
    Xtothed replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
