Activity Forums Adobe After Effects Expressions Text Y Position linked to null Y rotation
  • Text Y Position linked to null Y rotation
    Posted by Isaac Wolfram on August 1, 2011 at 5:45 pm
    I have a series of text rotating through the screen in 3d space. as they rotate through i need the position at the start to be higher in “Y” and then when the finish the rotation I need them to be lower in “Y”.
    The rotating text is linked to a null for the rotation value. I would like to create a script for the Y position in the text element so as the rotation changes in the null the Y position will change on the text.
    This isn’t a direct link because of the difference in values. I don’t know how to create this expression.
    Any help?
    Isaac Wolfram replied 15 years, 1 month ago 2 Members · 6 Replies
  • Dan Ebberts
    August 1, 2011 at 6:11 pm
    Is the text layer a child of the rotating null? Around which axis and in which direction is the null rotating? What’s the relationship between degrees of rotation and pixels of movement?
    >higher in “Y”
    Do you mean a higher y value (which would be lower) or a more negative y value (which would be higher)?
    Dan
  • Isaac Wolfram
    August 1, 2011 at 7:45 pm
    my man dan ebberts, i did first try to look through your site before posting here, thanks for replying.
    The text object, and illustrator file is a child of the rotating null. the null is rotating on the Y axis.
    I am having a difficult time finding the math to relate the Y rotation of the null to the Y position of the text object.
    I believe it’s:
    Start
    Text object Y -200
    Null Rotation -20
    End Pass out of Frame
    Text Object Y +155
    Null Rotation +67
    Attached are some screen shots, ignore the 4 text elements I’m just trying to make it work with 1 first before making it go to all 4.
    Who doesn’t fall, cannot rise.
  • Dan Ebberts
    August 1, 2011 at 8:08 pm
    The text layer’s position expression is probably going to look something like this:
    rStart = -20;
    rEnd = 67;
    yStart = -200;
    yEnd = 155;
    y = linear(parent.transform.yRotation,rStart,rEnd,yStart,yEnd);
    value + [0,y,0]
    Dan
  • Isaac Wolfram
    August 1, 2011 at 8:32 pm
    amazing, it works. is that an array?
    i’m shocked. thanks for taking the time to reply.
  • Dan Ebberts
    August 1, 2011 at 8:39 pm
    The last line adds an array ([0,y,0]) to another array (value–the pre-expression 3D value of the position property).
    Dan
  • Isaac Wolfram
    August 1, 2011 at 8:55 pm
    your expression saved me lots of key frames and made it much easier to do any ramps. seriously i can’t thank you enough.
