Activity Forums Adobe Illustrator Text wrap in illustrator
  • Text wrap in illustrator
    Posted by Joshua Weiss on June 6, 2005 at 7:27 pm
    OK, I am relatively elementary with Illustrator. I have version 10 if that helps. Let me explain exactly what I am doing so you can best aid me. I am working on a newsletter. My page has 2 vertical columns on it both of which are from top to bottom justified both sides. At the bottom of the page is an image coming in from about a third of the way up the right side of the page and going at about a 45 degree angle to halfway through the left column before it then shoots straight down. I want the text to stay justified both all the way down and I want it to continue until it gets to the diagnal image. This means that the left column would go all the way to the bottom of the page but the last several lines would only go half way across the column until it bumps into my image and has to go to the next line. HOW CAN I DO THIS? Right now I am having to pretty much just hit enter every time I want it to go to the next line. This begins to look sloppy.
    Joshua Weiss
    469-964-9077
    David replied 21 years, 3 months ago 2 Members · 1 Reply
  • David
    June 6, 2005 at 9:23 pm
    type > wrap > make
    (and see Illustrator help and/or user guide and/or Illustrator 10 Bible)
