Activity Forums Adobe Photoshop text unreadable after resizing document
  • text unreadable after resizing document
    Posted by Grady Knight on June 12, 2008 at 4:42 am
    I am using Ps 7. When I add text to a map I am working on then resize the map to 50% the text becomes unreadable. I believe that I am making the text large enough to read at 1/2 the size but much of the text has ragged edges and the vertical strokes seem twice as thick as they should, looks like blobs from a leaking pen.
    I know that there must be something that I should be doing to the text before I resizes the document but not sure what.
    Also if I increase the size of the document it also ruins the text edges.
    Should I be resizing to my final size before I add text? I would have to do two separate maps for that, need two final sizes.
    Thanks in advance if you can help me with this.
    Grady Knight replied 18 years, 3 months ago 3 Members · 6 Replies
  • Richard Harrington
    June 13, 2008 at 12:15 am
    Are you just changing zoom size or the image size.
    Text is vector.
    Check the anti-alias settings you are using i n the Options Bar
    look up antialiasing in help menu
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Grady Knight
    June 13, 2008 at 4:48 am
    Tried looking it up. Said to turn of anti-alias go to Edit -> Preferences -> General. I look there and cannot find anything about anti-alias. Am I looking in the wrong place?
    8mm & 16mm film to DVD
  • Ian Schmoel
    June 16, 2008 at 10:54 pm
    Is the file a PSD or are you working with a flattened image? In other words, are you flattening the image and then resizing it?
  • Grady Knight
    June 17, 2008 at 3:30 am
    Yes I am working with a .psd and yes I flattened the image before I resized it. I am only resizing it because I need one samll for a web page and a larger pdf file for downloads.
    Maybe I need to just make two different documents?
    Thanks for your help.
  • Ian Schmoel
    June 17, 2008 at 2:18 pm
    Duplicate the PSD, resize it and then flatten it. Your text should hold up then.
  • Grady Knight
    June 20, 2008 at 5:39 am
    Thanks, I just got back and will try it out tomorrow.
