Activity › Forums › Adobe After Effects › Text type on effect with blinking insertion bar
  • Text type on effect with blinking insertion bar
    Posted by Andrew Wilson on January 17, 2012 at 4:02 am
    Once upon a time I had a plug in for AE that would animate text like it was being typed on the screen and you could easily add a blinking (or not) insertion bar or a square so it looked more like a screen capture.
    Does that still exist somewhere? Is there an easy way to do that in the newest version?
    Andrew Wilson
    WestView Digital Video & Design
    http://www.westviewdigital.com
    Andrew Wilson replied 14 years, 7 months ago 2 Members · 3 Replies
  • John Cuevas
    January 17, 2012 at 3:15 pm
    You can try the Underscore preset in the text animations or
    Re: Computer type write effect
    by gimmel on Feb 1, 2007 at 9:24:27 am
    Put the following code into the Sourcetext expression. Use a slider to animate n.
    Isn’t that easy?
    n=8;
    showtext=text.sourceText.substr(0,n)+”_”;
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Andrew Wilson
    March 6, 2012 at 3:58 pm
    Thanks! I’m almost there. I’ve been using Motion for so long that I don’t know how to add a slider and animate the N value for expressions.
    (My knowledge of expressions is VERY limited)
    Andrew Wilson
  • Andrew Wilson
    March 6, 2012 at 4:18 pm
    nevermind. I figured it out. Man, I wish I still had that old plug in. It did blinking cursors and everything including randomizing the amount of time between keystrikes.
    Almost makes me want to fire up my old G3 to see if it’s still installed on there.
    Andrew Wilson
