Activity › Forums › Apple Final Cut Pro Legacy › Text Tool: Title Crawl
Posted by Sascha Engel on May 18, 2011 at 7:00 pmI have to run titles on the bottom of the screen (from left to right / hebrew).
Unfortunately, it runs a bit staccato, not so smooth, which makes it hard to read.
Any other Generator to get a better result in FCP, or a tip, how to smoothen the Crawl Title Generator?Thanx.
Sascha
Sascha Engel replied 15 years, 3 months ago 3 Members · 11 Replies -
Rafael Amador
May 18, 2011 at 8:38 pmHi Sascha,
I haven’t use a crawl since ages, but I would try the FCs “Boris Crawl”.
rafael -
Rafael Amador
May 18, 2011 at 9:38 pm[Sascha Engel] “I don’t have Boris :-(“
yes, you have it, or you should have it because comes bundle with FC since I can remember.
Look in the text tools; you should have a Boris folde.
rafael -
Sascha Engel
May 18, 2011 at 9:48 pmYup, found it.
And amazing enough: It even has a direction change for Hebrew!!!!! 🙂Thanx a Lot!
Sascha Engel
May 18, 2011 at 10:02 pmHI Raphael,
I still havve the problem, that despite all the fancy options – the text is quiet unreadable.
Any special adjusyment I might not be aware off?Sascha
Rich Rubasch
May 18, 2011 at 10:31 pmIs it rendered? Do you have a green line or orange?
What are the sequence settings?
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
https://www.tiltmedia.com -
Rafael Amador
May 18, 2011 at 10:37 pm -
Sascha Engel
May 19, 2011 at 5:33 amYes, it is rendered. The Sequence Settings are Full HD size (1920*1080), ProResHQ.
Sascha
Rafael Amador
May 19, 2011 at 3:58 pmSascha,
p25 will makes any animation more choppy than i50 or p50. I guess that a fast Crawl may look very jumpy.
But not sure if that is the problem when you say that the picture is unreadable.
The Boris filter has a “De-flicker” filter, but that should works for rolling text.
I would try something like applying some (.5) Horixontal Blur to the text.
Without having a look is difficult to imagine the real issue.
rafael
