Activity › Forums › Adobe After Effects › Text to smoke
Text to smoke
Posted by Nathan on September 25, 2006 at 11:06 pmI want to display some text then have some other text appear behind and the top text turn to smoke as the bottom text appears to come through the smoke. Any idea of where I can start? Or how to achieve this? Any advice, tips, links and tutorials are greatly appreciated.
Arun Kumar replied 16 years, 12 months ago 6 Members · 6 Replies -
Justin Productions
September 26, 2006 at 12:40 amLinks: COW’s Archives.
Tutorial here.
Tips: Get Trapcode Particular and get the PyroPack (at the bottom of the page). See here and click on the “Text to smoke” index to the left.
Really…really hope that helped 🙂
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.5 Professional -
Mark
September 26, 2006 at 12:48 amCreate a comp. Call this comp noise comp. In this comp apply fractal noise to a solid. Adjust and animate fractal noise to look smokey. It may take a bit of tweaking, but it is really not that hard. Adjust the transform of the fractal noise to rise, such as smoke would.
Now, bring this comp into your second comp, the one that has your text. Close the visibility of the noise comp.
Apply the displacement map filter to your first text and select the noise comp as your displacement map. I would suggest using the luminance channels for the distortion.When you want the text to go up in smoke, animate the text’s position slightly with a big ease towards the upper portion of the comp, at the same time animate the distortion amount of the distortion map from 0 to a good value (depends on the size of text and amount of distortion wanted). You can also animate a blur to the text.
To complete the effect, duplicate the text, and use it as a track matte for the nois comp (turn back on the visibilty of the noise track). Now make sure that these two layers are above the original text and animate the opacity values of the noise comp from 0 to 100 at the point where the text starts to move.
Now, to get the other text to move through, create the move on the second text (zoom I would presume). Once the move is good enough, then duplicate this text layer and place the duplicate at the top of the comp. Now animate it’s opacity at the point where it looks like it should come through the smoke. For added realism, you can use the noise comp as a displacment map to these two text layers as they move through the smoke.
Hope this gets you started
Mark
David Bogie
September 26, 2006 at 2:16 pmYou can download a boat load of remarkably simple text effects here:
https://theanvel.com/Look for the NAB2006 set of tutorials.
https://theanvel.com/free_aeps_detail.php?aeps=77
bogiesan
Nathan
September 26, 2006 at 3:20 pmwow thanks all. I seriously appreciate it. I did “rtfm”. Well I didnt read it all but I did search through it. Also looked through some training dvds I have but didnt find this wealth of knowledge. But the good thing is its a part of the matrix now. So if someone else needs this help its there now 😀
Many thanks to ya’ll
Suner Cheng
August 23, 2008 at 5:35 pmhello!TObias Lind,The tutorial :Making Titles or Objects Turn to Smoke and Disappear,So cool! I like it very nice your tutorial.I am only a little English, I am sorry!
I come from China, I very much like your tutorial, but how do it?
please send me an email with either the project file or an effect preset? My address is suner.cheng@163.com,
very grateful!
