Activity Forums Adobe After Effects text switch
  • text switch
    Posted by Dan Newton on November 9, 2012 at 7:38 am
    Hi
    I need to know how to do the following:
    I have a piece of text which I like to switch around/twirl around to reveal another piece of text.
    Could you let me know how to do something like that.
    Much Appreciated
    John Cuevas replied 13 years, 6 months ago 2 Members · 2 Replies
  • John Cuevas
    November 9, 2012 at 12:52 pm
    When you say switch around/twirl do you mean that it rotates on one of it’s axis 180 degrees and on the reverse side is a different word?
    If that’s the case, create both text layer and place the anchor point in the center of the text layers. Enable 3D for each layer and animate/keframe the rotation of one layer 0 to 180 degrees on it’s X or Y axis. Parent the 2nd layer to the first. Now as you scrub you should have a back and front layer.
    Now open your opacity controls(T)and alt-click the stopwatch to enable expressions and paste this expression: if (toCompVec([0, 0, 1])[2] > 0 ) value else 0. It turns off visibility of layers that aren’t facing forward.
    To learn more about this expression go to https://motionscript.com/design-guide/invisible-facing-away.html
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    March 13, 2013 at 8:45 pm
    Hope that helped.
    Thinkck.com
