  • Posted by Tom Gomez on February 11, 2012 at 7:41 pm
    I’m crashing on a project this weekend… hopefully someone will see this! 🙂
    Linking expressions using layer and comp names.
    This is easy:
    n1 = thisComp.name.split(” “)[0];
    comp(“MASTER PERIODIC TABLE”).layer(“MASTER CONTROL”).effect(n1)(“Color”)
    My layer name is “11 Na Sodium”. (Doing a fancy science anim.)
    But what if I need my effect in MASTER PERIODIC TABLE to be “11 Na COLOR.”
    How do I string together text snippets and add the world COLOR?
    n2 = thisComp.name.split(” “)[1];
    comp(“MASTER PERIODIC TABLE”).layer(“MASTER CONTROL”).effect(???????????????????????????)(“Color”)
    Thanks MUCH for any help.
    -Tom
    YOU can help save TimeSpace. Join the Chronos Protectorate!
    https://www.95ers.com
    https://www.SpaceAceMedia.com
    Tom Gomez replied 14 years, 6 months ago 1 Member · 1 Reply
  • Tom Gomez
    February 11, 2012 at 7:53 pm
    Thanks to one of Dan’s earlier posts I found the answer. THANKS DAN!
    n1 = thisComp.name.split(" ")[0];
    n2 = thisComp.name.split(" ")[1];
    comp("MASTER PERIODIC TABLE").layer("MASTER CONTROL").effect(n1 + " " + n2 + " ind COLOR")("Color")
