Activity Forums Adobe After Effects Text streaks into Background
  • Text streaks into Background
    Posted by Joeythedog on August 21, 2005 at 9:46 pm
    My text raises slightly turns -104 degrees on the y axis and streaks into the background scaling smaller and losing opacity. I would like it to have a light streak trail to express velocity. This can be streaks or maybe particles. What effect could I use for this. and a little how to.
    joe
    Joeythedog replied 21 years ago 2 Members · 3 Replies
  • Joeythedog
    August 22, 2005 at 5:36 am
    I got it. 🙂
  • Matt Stoltz
    August 22, 2005 at 2:39 pm
    just curious of what you did here
    matt
  • Joeythedog
    August 22, 2005 at 8:27 pm
    This is pretty basic but looks good. I used cc light burst 2.5 effect.
    My text “Star Base” I made a new text layer and just typed “l”. I applied the effect to this layer. Background black. I put the center at the vanishing point where the text was moving to. And i put the “l” at the very end of the text line and parented “l” to the text “STAR BASE” After you parent it you have to move it into correct position again, no key frames necessary.
    So after the text makes it’s turn toward the distant background 2 frames after it starts shooting towards the distant reaches of space the “l” layer becomes visible,just the streak effect not the letter “l”, a streak the same pixels height as my “STAR BASE” and it looks like a rocket that just turned on the after burners.
