Activity Forums Adobe After Effects Expressions Text Source expression for unicode ornaments
  • Text Source expression for unicode ornaments
    Posted by Armand Bakx on August 18, 2021 at 12:21 pm
    Hello,
    A bit of a specific request for help: While working with Text Source expressions I ran across a problem. In this expression-output I want to use a specific glyph (a cross) of the typeface Riforma LL, which is used in the projects’ identity. I wanted to access this glyph by its unicode escape sequence. In the Glyphs panel of Adobe Illustrator I found that the glyph I want to use is referenced as “U+2022 Ornaments#11 (ornm11)”. Using ‘\u2022’ as an escape sequence resulted in the wrong glyph (a bullet point), but I don’t know how else to reference it.
    Is it possible to reference this one specific glyph properly? And if yes, how do I achieve this?
    Thanks in advance for anybody that’s able and willing to help me!
    Armand
    Armand Bakx replied 5 years ago 1 Member · 0 Replies
  • 0 Replies
