Activity Forums Maxon Cinema 4D Text sitting on a curve
  • Text sitting on a curve
    Posted by Jack Sewell on September 21, 2010 at 8:45 am
    Hi all,
    I have some text on a hill. I’d like the all of the letters to sit on the terrain as oppose to just the first and last letter with a gap in between the rest. The text is a text object in an extrude nerbs. Is there a way of achieving this without making each letter a separate nerbs object?
    Many thanks,
    Jack
    Adam Trachtenberg replied 15 years, 11 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    September 21, 2010 at 2:31 pm
    AFAIK there’s no way to access the individual positions of letters in a text spline, so you’d have to make it editable if you go that way.
    If you have Mograph you could use the text object instead, which gives you many options.
