Activity › Forums › Adobe After Effects › text selectors multiple changes
  • text selectors multiple changes
    Posted by Alex Udell on November 3, 2011 at 8:16 pm
    Hi…
    don’t know why I’m having so much trouble with this….
    Let’s say I set up a text animation using selectors and offset that
    takes $10,000
    and each character zooms, spins, and fades in sequentially
    so I set up my adjusted values on position, opacity, and rotation
    and i set up my offset keyframes….works fine
    now my brain breaks…
    on that same $10,000
    but later in time I want to give the characters a sequential vertical bounce…or a position change.
    Now that I have already set a range selector and am using that with position….
    how do I do further editing to the same text obejct?
    Sorry if I’m dense…
    thanks,
    Alex
    Alex Udell replied 14 years, 11 months ago 2 Members · 2 Replies
  • Angie Taylor
    November 4, 2011 at 11:56 am
    Hi there,
    To add a position bounce with it’s own range selector . . . instead of adding a property to the existing animator. Add a completely new animator by clicking on the “Animate” flyout menu (as opposed to the “Add” flyout menu).
    Hope this helps!
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Alex Udell
    November 4, 2011 at 7:05 pm
    Thanks ANgie…
    I don’t see an option to add a new animator as you describe….
    but I can do it if I take my existing animator and duplicate it….
    then I reset it and work from there….
    thanks again!
    Alex
