Activity › Forums › Apple Final Cut Pro Legacy › Text Screen inside FCP crashes
Posted by Steven Koeppen on January 5, 2008 at 9:10 pmIf I click on the text generator in Final Cut Pro I get the sample text screen. But when I click on the control tab to type in text, FCP crashes every time. This happens with any of the text generators inside FCP. I used Font Book to validate fonts and it found 3 “bad” fonts. I deleted them but still have the same problem.
What else should I look for?
StevenMacPro 2x 3GHz Quad-Core 8GB RAM 500GB HD
FCS 2Hector Berrebi replied 17 years, 6 months ago 5 Members · 4 Replies -
Jerry Hofmann
January 6, 2008 at 5:16 pmDollars to doughnuts you have another bad font in there… MOVE any fonts you’ve installed yourself, then put them back in groups or something to narrow down the baddy?
Jerry
Chris Blankenship
August 7, 2008 at 9:31 pmI had this same problem and replied with this to another posting, but in case you didn’t see it…
OK, so I checked out some other postings and it was suggested that corrupted fonts or other font issues might be the cause. I bought a program called Smasher from Insider Software for $50. It was about the best 50 bucks I’ve spent. It IMMEDIATELY resolved the issue. You need to “Smash the Cache” to fix the problem I had, but it was very fast. When it rebooted I was a little worried as it looked stuck with some startup issue and wouldn’t boot up. I’m not saying I recommend this, but after about 10 minutes I hit the power key on the front and restarted. Came right up, and FCP text works like a champ again.
My 2 cents.
Kerik Ino
March 8, 2009 at 1:23 amI have also used a “Font Smasher” that “Smashes” your font cache but haven’t had any luck. I had to create a new user on my system once upon a time and i think i may have tainted my permissions some how.
Paying for software like FCP is hard… wink wink… so we have to cut corners and sometimes getting software from “cheap” sources… wink wink… can result in more back end work than say… paying for it in full from adobe.
Okay
Hector Berrebi
March 8, 2009 at 12:24 pmOBVIOUSLY this belongs to another thread… don’t know how to delete this…
sorry
hi Rob
next time you can set an easy setup at the begining of your work that matches your format.
also, if you are on version 6 (which you should be) when you drop the first clip in a timeline FCP will ask you if you want the timeline to match the clip or clip to match the timeline. make the timeline match and work from there.
for now, duplicate your sequence
change the sequence settings to this
in the video processing tab put best on motion FX like this
then, select all clips on your timeline.
right click and remove attributes,select to remove basic motion and distort
should put your timeline back to DV pal, might need to render, but far less than what you had to on an XDCAM timeline
if any resizing rotating or movement was done on a clip,
redo if simple, or copy from other sequence if keyframed and complex and just adjust the right sizegood luck
Hector Berrebi
Schibber Group
prePost Consulting
