Activity Forums Adobe After Effects Text Rotation Problem
  • Text Rotation Problem
    Posted by Juhani Hakanen on September 5, 2009 at 10:59 am
    Hey,
    I have a problem rotation a 3d text layer’s y axis.
    When I turn it for example 90 degrees, the position value doesn’t change but the layer’s position definately changes (i see it).
    I want the center of the text to stay in the exact same position when I turn the text 90 degrees. How to do this?
    Andy George replied 16 years, 12 months ago 2 Members · 1 Reply
  • Andy George
    September 5, 2009 at 5:50 pm
    Juhani,
    You need to move the layers Anchor point to the center of the text.
    This is the point that the layer rotates around.
    You can do this without modifying the layers position by using the Pan Behind Tool.
    Its the one that looks like a dotted line square with a target in the middle of it.
    -Andy
