Activity Forums Adobe After Effects TEXT Roll Animation
  • TEXT Roll Animation
    Posted by Dawud Ali on April 24, 2011 at 3:39 pm
    hi guys
    Thanks for your time and help
    i wanted to animate the date 2001 and evolve it to 2011. i thought i knew how to do this but i can’t. the animation i wanted to achieve was
    this(skip to 1.02):
    https://vimeo.com/21753673
    this is my fiends piece she’s busy working today so i can’t ask her direct.
    thank you in advance
    Dawud Ali replied 15 years, 5 months ago 2 Members · 5 Replies
  • Brian Charles
    April 24, 2011 at 7:06 pm
    You’ll need to animate the Character Offset using 2 separate animators, one for the last digit and one for the penultimate digit.
    Restrict the range of each animator to a single digit. The penultimate one should only animate when the the last digit turns from 9 to 0.
  • Brian Charles
    April 24, 2011 at 7:47 pm
  • Dawud Ali
    April 24, 2011 at 9:39 pm
    Thanks for the help but some further question if you plesde.
    firstly how do i set the penultimate digit from the animators once i get the character offsets? (i’m very inexperienced with text animation).
    secondly how would i apply the ‘penultimate digit’ for more than one for number. example in a digital clock or airport information boards
  • Brian Charles
    April 24, 2011 at 9:49 pm
    Please refer to the manual and help for After Effects.
    Text animation is controlled by animators.
    I assumed you had some understanding of the software.
  • Dawud Ali
    April 25, 2011 at 1:36 am
    haven’t worked much with text animators, v.useful to learn them inside out. guess i need to rush to the manuals
