Activity › Forums › Adobe After Effects › Text Rippling – Similar to water waves
  • Text Rippling – Similar to water waves
    Posted by Phillip Roh on October 10, 2007 at 1:10 pm
    Imagine the smooth motions of gentle waves of water. I have a text slate where I would like it to have a bit of that feel. Just basic white text on black background, but I’d like the text to ‘wave/ripple’ just a bit to add some motion to the slate.
    The things I found on the site were for concentric water drop motions. I’m thinking of more directional motions (e.g. left to right wave).
    Phillip Roh replied 18 years, 11 months ago 3 Members · 3 Replies
  • David Bogie
    October 10, 2007 at 2:13 pm
    Apply WaveWorld to a solid.
    Use the solid as a displacement map.
    It is lovely, programmable, utterly controllable and supremely ultrarealitistic.
    WaveWorld is complex because it is so cool. Not for the timid.
    bogiesan
  • Kevin Camp
    October 10, 2007 at 2:28 pm
    waveworld is an excellent wave simulator… i might also suggest using it in conjunction with caustics for more realism of displacement… it can also give your waves highlights, or even a reflecting sky, if that is what you’re after. but what bogie said about wavworld goes for caustics too… they are not the easiest plugins to use, but excellent non the less.
    if you want something easy, that can create a watery ripple-like movement, turbulent displace may work quite well, and it is very easy to use…. its settings are a bit like fractal noise, animate the evolution property, then adjust the amount, size and complexity.
    with turbulent displace, you’ll at least be able to see if this will work for you in about 5 minutes… with waveworld it might be more like an hour.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Phillip Roh
    October 10, 2007 at 3:09 pm
    Thanks bogie & moldy! I’ll try Wave World first and see how it goes. But sounds like turbulent displace will be easier for me :D. I’ll try using the caustic filter too. Thanks!
