Activity Forums Adobe After Effects Text reveal – up then down
  • Text reveal – up then down
    Posted by Guilherme Oliveira on January 22, 2013 at 6:15 pm
    Hello,
    I’m trying to get a text revealing effect with some masks and text animators. Here’s what I want:
    https://youtu.be/hdF4TObRA4U
    I animated every letter individually to get this result but it’s not as fluid and smooth as I want.
    The goal here is the characters coming from “under the floor”, up a little bit and then “sitting” on the final position. I’m pretty sure that there’s a easier way to do so by using text animators or something like that because letter by letter animation takes a really long time.
    Thanks in advance.
    Guilherme Oliveira replied 13 years, 7 months ago 2 Members · 2 Replies
  • John Cuevas
    January 22, 2013 at 8:12 pm
    The term for this is called “overshoot”, so if you want to explore other options, that’s what you are looking for.
    You can do it with a couple of text animators, one for up and one for down. Here’s a quick little project I made. I just offset the “start” position and the “upper” to create the bounce Take a look at the project and if you have any questions, let me know.
    5278_textanimators.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Guilherme Oliveira
    January 22, 2013 at 10:24 pm
    Now that I know the name I found a bunch of stuff about it! Thanks and thanks for the project
