Activity Forums Apple Final Cut Pro Legacy Text resizing on export – why?!
  • Text resizing on export – why?!
    Posted by Alex Bond on August 20, 2011 at 8:47 pm
    Hi guys,
    I’ve been trying for hours to work around this and have now had enough!
    I’ve 16×9 footage on a timeline, putting text on it, exporting it uncompressed anamorphic. Text is staying the same size so when the QT is imported into DVD Studio (or just played) the text is the wrong aspect ratio and becomes stretched out on a 16×9 screen.
    What am I missing here?
    I’m using an old FCP 4.5, footage is QT imports, sequence settings are the in built DV PAL 48k ones.
    It’s wrecking my head now!
    Best
    Alex
    Alex Bond replied 15 years ago 2 Members · 2 Replies
  • David Battistella
    August 20, 2011 at 8:53 pm
    duplicate the sequence.
    Selct all of the titles and the CUT.
    Change the aspect ratio of the sequence.
    Paste the text into the new sequence.
    The text will all be the correct aspect ratio now.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
  • Alex Bond
    August 20, 2011 at 8:57 pm
    Great! Thanks very much.
    While I was waiting for a reply, I just tried changing the export settings too – seemed daft but anamorphic 1024×576 has also fixed the issue.
    Just couldn’t work out why the text was doing it’s own thing independently of the timeline… (used to Avid and Media 100)
    Cheers for the alternative answer 🙂
