Activity Forums Adobe After Effects Text question…
  • Text question…
    Posted by Aza Allen on March 28, 2008 at 3:06 am
    This might be a noob question, though I am pretty familiar with AE7 – I have a blach & white photo, I have some black text moving across it, how do I get the text to lighten in the parts that cross the dark areas of the photograph?
    Thanks for any help,
    Aza
    Make sure to check out my Heroes Fan Film at http://www.myspace.com/ruesterprod
    Jacob Wessler replied 18 years, 5 months ago 2 Members · 2 Replies
  • Aza Allen
    March 28, 2008 at 5:01 am
    Oh and one more thing… for some reason the aforementioned text isn’t casting a shadow with a light on it, but everything else is casting shadows. It is in a 3D layer, I also checked all the material properties’ settings and they’re the same (cast shadows, accepts lights: on)Is there something I am missing?
  • Jacob Wessler
    March 28, 2008 at 1:46 pm
    Aza,
    You can set the blend mode of your text layer to “Difference.” This would make the text white when it was over black, and black when your picture is white (of course, it’ll also do all the shades inbetween. If you want more control, you can create a gradient layer behind your text and pre-compose it. That will give you options for controlling when the text changes color. You could also animate a gradient (use the ramp effect for a simple gradient, or the 4-color effect for more color control).
    As for the shadows, is your text layer close enough to the layer below it to cast the shadow? If the text is too far away, the shadow will have dissolved by the time it “reaches” your layer.
    Hope that helps,
    Jacob
