Activity › Forums › Adobe After Effects › Text Question
Text Question
Posted by Mark Almond on November 22, 2009 at 2:24 amHi All
I have two pecies of text on my screen and I want to move pone peice of it off the screen but when I start to move it of the screen the other peice of text goes the other way which I don’t want, I just want the second peice to stay where it is, how can I stop it from doing this?
Any help would be much appreciated
Mark
David Johnson replied 16 years, 10 months ago 3 Members · 6 Replies -
Charles Ferran
November 22, 2009 at 3:21 amDo you have both pieces of text in the same layer? if so, you need to delete one piece of text and create a new text layer, then type your second text in there. then you will be independently moving two pieces of text.
Sorry if this is a little obvious but your question was pretty broad and I don’t know what your skill level is.
Mark Almond
November 22, 2009 at 11:50 amYeah both peices of text are on their own layers.When I drag one peice of the text towards the left of the screen, the other peice of text moves in the opposite direction unless this is the screen moving, I’m a newbie to after effects.
Mark
David Johnson
November 22, 2009 at 3:14 pmHow did you create the text layers? With a preset? If so, there is probably an expression that is part of the preset that is causing that to happen … check the layers in the timeline for expressions and/or keyframes. Since you are somewhat new to AE and may be unfamiliar with editing expressions, your best option will probably be to recreate the text layers without using the preset/expression.
Or, if that will mean losing some aspect of the text that you want to retain, you might be able to duplicate the layers and mask out the portions you don’t want to see on each duplicate … in other words, the pieces of text would still move relative to each other due to the expression, but you won’t see the parts that are masked.
Mark Almond
November 22, 2009 at 3:30 pm -
Mark Almond
November 22, 2009 at 3:59 pmI’ve also added a screen recording to give you an idea of what what is happening
https://www.youtube.com/watch?v=D2wnPiDLo0EThanks
Mark -
David Johnson
November 22, 2009 at 7:07 pmEspecially since it doesn’t happen the first couple of times you move the text, it looks like the “maja-media.co.uk” text layer is not actually moving … rather, that the comp window is just adjusting to the left when the other text is moved beyond the viewable area of the comp window, which can give the appearance that the “maja-media.co.uk” text is moving.
Try setting your comp viewer to a size that will allow you to move the text to where you want it without pulling it out of the viewable area. To confirm whether it is actually moving, you might also set a temporary position keyframe for the “maja-media.co.uk” text layer, lock it, move the other text, then check whetehr there is any change in the “maja-media.co.uk” layer position.
