Activity Forums Adobe After Effects text quality
  • text quality
    Posted by John O’brien on April 12, 2006 at 5:32 pm
    I am building a project whose video elements were shot in NTSC DV Widscreen. My comp base on this footage defaults to a 9:5 pixel aspect/ My text output on sample DVD burns using iDVD at Best Quality is poor- especailly with the serifed fonts. What am I probably doing wrong? How you anyon advise me to correct this situation? Thanks.
    John O’Brien
    John O’brien replied 20 years, 5 months ago 2 Members · 4 Replies
  • Harryjf
    April 12, 2006 at 5:50 pm
    What are you format and codec are you rendering to?
    It sounds like you might me rendering this to a DV format, which will look terrible, especially with serif type.
    If this is for DVD, there is nothing stopping you from rendering to a lossless format, and using that as your source in iDVD.
  • John O’brien
    April 12, 2006 at 5:53 pm
    I am rendering in Animation at 100%- no keyframes or adjustments. I think the text is being screwed up in the translation in aspect ratios between
    the original comp and how iDVD comprsses it but I don’t know for sure.
    J.
  • Harryjf
    April 12, 2006 at 6:16 pm
    Oh yes.. sorry. You are right. iDVD doesn’t handle pixel aspects of 9:5.
    What about this..
    Put the final comp into a d1/dv comp, and fitting the comp to size (opt/command-F or alt/ctrl-F).
    This should deliver the proper aspect that iDVD is looking for.
  • John O’brien
    April 12, 2006 at 6:22 pm
    thanks- I’ve been exposed to this idea before nice to have it on paper.
    J.
