Activity Forums Apple Final Cut Pro Legacy Text quality Vector + Title 3D
  • Text quality Vector + Title 3D
    Posted by Maria-luisa Meredith on February 18, 2013 at 1:33 pm
    Hi
    I have a Pro Res sequence that contains video (1440 x 1080 HDV), overlaid with text captions (Boris Title 3D) and some logos (Photoshop layered PSD).
    This all looks great in FCP and great when exported to a full quality .mov but I need to play the final output from a DVD onto a big screen, I know some loss of quality is unavoidable here (HD to SD) but at the moment the moving images look great and all the text elements are ghosting slightly.
    Is there a good work flow to maintain crisp text on my DVD playback?
    Many thanks in advance.
    M
    Macbook Pro / OSX 10.6.4 / 2.4GHz Intel Core i5 / 4GB 1067 MHz DDR3
    FCP Studio 7.0.2
    Maria-luisa Meredith replied 13 years, 6 months ago 2 Members · 5 Replies
  • John Pale
    February 18, 2013 at 4:26 pm
    HDV uses non square pixels. Thats why its 1440 x 1080. The edit system should automatically stretch HDV to fill the 1920 x 1080 frame.
    If you work in a Pro Res sequence set to normal 1080i dimensions, 1920 x 1080, with square pixels, the HDV video should resize accordingly and not appear squeezed.
    You then make your graphics with square pixels at 1920 x 1080…not 1440 x 1080. Everything should appear clean.
    Then you down convert for DVD. Things should improve with this workflow.
  • Maria-luisa Meredith
    February 18, 2013 at 6:21 pm
    Hi
    Thanks for your response, I tried reducing the frame size of the graphics (created by someone else) in Photoshop first but as they’re not exactly 16:9 I couldn’t get exactly 1920 x 1080. I’ll try to do that with some cropping though.
    Thanks again,
    M
    FCP Studio 7.0.2
    February 18, 2013 at 10:33 pm
    Hi
    Here are the details you asked about:
    Frame Rate? 25fps
    Progressive or Interlaced? Recorded 1440 x 1080 HDV 50i.
    16×9 or 4×3 on the DVD? 16:9.
    DVD playback device displaying the ghosting? Sony Bluray DVD player via 2K digital projector.
    What will the ultimate playback device be? As above.
    Does this clarify where my issue lie at all? Many thanks,
    M
    FCP Studio 7.0.2
    February 18, 2013 at 10:55 pm
    Hi
    I just played the DVD in an old DVD player on a CRT TV and it looks good, not as crisp as the Pro Res QT’s but ok.
    The ghosting is more than just the expected jagged edge text, it looks as though there is noise around the lettering of the title 3D text and the vector logos.
    M
    FCP Studio 7.0.2
    February 18, 2013 at 11:18 pm
    Hi Dave
    Thanks for your input. It seems a pity that high quality work has to look less good on delivery (unfortunately the AV company who are going to run this one don’t have Bluray playback). Out of interest would a Bluray DVD improve my issue with the graphics and text?
    I just wanted to be absolutely certain that some innocuous setting somewhere in my SD DVD workflow was not causing my text to lose quality like this.
    Thanks again.
    M
    FCP Studio 7.0.2
