Activity › Forums › Boris FX › text quality comparison?
  • text quality comparison?
    Posted by Sean Brennan on August 21, 2009 at 11:44 pm
    Text I create in Boris RED looks a tiny bit jagged around the edges both in the composite window and when rendered to premiere timeline, yet the same text I replicate in Premiere Pro’s titler looks so much better, softer and more professional when placed side by side!
    Why is this, I have set all Boris settings to High and Full Res…have I missed something?
    thanks guys
    Matt Mullen replied 16 years, 11 months ago 6 Members · 15 Replies
  • 15 Replies
  • Peter Mcauley
    August 24, 2009 at 11:09 pm
    Hi Sean,
    The text from RED should be razor sharp – are you generating raster or vector text? If it’s raster, try converting it to vector. You can do that in RED by clicking on the track type icon on the text track (to the left of the “Eyeball” icon) and setting it to 3D Line Art.
    Hope this helps!
    Peter.
  • Paul Taylor
    August 25, 2009 at 12:42 am
    Hi Peter thanks for the reply.
    Unfortunately this doesn’t help. I create vector text by clicking add vector text icon, type some text in text window (which looks perfect at this point) but viewed in the timeline or boris monitor window it’s not as smooth. Edges are more jagged like it hasn’t been aliasing. Where are the settings for text quality ie hard, soft, smooth anti aliasing on/off etc ?
    thanks
  • Sean Brennan
    August 25, 2009 at 2:14 am
    Thanks for the help Peter sadly it doesn’t work. I create vector text by clicking on the icon, type something in the text window that pops up and whilst it looks good in there, in the monitor window and rendered to premiere it’s jaggy. I’ve tried different fonts and different sizes. Premiere’s own titler still looks Anti-aliasing and much smoother when I replicate this title. Can you tell me where are these aliasing settings in Boris RED, failing that, anything else I could try?
  • Peter Mcauley
    August 25, 2009 at 2:31 am
    Hmmm … you might want to go to the project settings pane by selecting Edit>Project Settings and click on the 1:2:1 Deflickering option to see if that helps. Note that you wont’s see a change until you close the Project Settings window.
    Cheers,
    Peter.
  • Peter Mcauley
    Cheers,
    Peter.
  • Sean Brennan
    August 25, 2009 at 3:47 am
    hmm, it made a tiny bit of difference. Please take a look at my screen caps: https://www.yousendit.com/download/YkxJblR0UnFCSWV4dnc9PQ
    zoom in and you’ll see what my issue is. If you have any other suggestions please let me know, thanks for you time.
  • Peter Mcauley
    August 26, 2009 at 1:17 pm
    Hi Sean,
    Thanks for sending the screenshots – they really help in our understanding of the result that you are seeing. I’m forwarding the images and description to engineering to see if someone knows why the text is appearing aliased and not as smooth as expected.
    Peter.
  • Christopher Wright
    August 26, 2009 at 6:36 pm
    Sean,
    are you editing with HDV or DV footage?
    If so, those codecs really destroy any text or compositing treatments to your original footage.
    Also are you viewing the output on a real TV monitor or just the Premiere Canvas??
    This will also make a difference.
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Nehalem Octocore 12 GB Ram, Nvidia card, MBP, MXO, MXO2 mini, Windows Vista Adobe Studio CS4, Vegas 9.0, Lightwave 9.6, Sound Forge 9, Acid Pro 7, Continuum 6, Boris Red 4, Combustion 2008, Sapphire Effects
  • Sean Brennan
    August 26, 2009 at 10:31 pm
    I edit with DV. I view on the premiere canvas.
    Premiere Project settings were DV-PAL Standard 48khz. A New Boris Composition was added 720X576 D1/DVPAL. Vector text created and applied. The resulting still image dragged from bin to the timeline. The result was jagged. Using the same technique but with the premiere titler (same settings) the result is smooth on the same canvas as indicated by the print screen upload.
    Interesting, I have just exporting the boris title from premiere to a .tiff file and viewed it in Photoshop … Now it displays perfectly smooth. Very strange.
  • Peter Mcauley
    August 26, 2009 at 10:50 pm
    Hi Sean,
    I have a sneaking suspicion that it’s a problem with fielding in Premiere Pro. It may be something in RED/Graffiti or it may be something in the host. We won’t really know until one of the engineers takes a look into the code.
    As soon as I hear back from them I’ll pass that info along.
    Cheers,
    Peter.
