Activity Forums Apple Final Cut Pro Legacy Text Produces Drop In Brightness
  • Text Produces Drop In Brightness
    Posted by Ravi Kanda on August 26, 2010 at 11:03 pm
    Hi guys
    When I add text to my video, the point when it comes in and goes out, I experience a drop in brightness. Once the text disappears, everything is back to normal again.
    Any ideas what I’m doing wrong?
    I’ve added no fades to the text.
    Ravi Kanda replied 16 years ago 2 Members · 7 Replies
  • 7 Replies
  • Ravi Kanda
    August 27, 2010 at 10:55 am
    This is what I mean.
    When the text comes in, the brightness reduces. When it fades out back, the video gets brighter again. Could it be missing frames?
    I’ve uploaded my problem onto youtube:
    https://www.youtube.com/watch?v=520BlKEiHZk
    If you cannot see the video well, download the mov file here:
    https://www.sendspace.com/file/8ldrya
  • Joy E reed
    August 27, 2010 at 2:28 pm
    Looks like luma shift. This is caused by processing renders in RGB color space not YUV. It’s a sequence setting called ‘Video processing’ – think it’s in the A/V prefs. Let me know how it works out.
    Peace & respect,
    Joy E. Reed
    http://www.ohmyproductions.net
  • Ravi Kanda
    August 27, 2010 at 8:11 pm
    Hey Joy
    Thanks for your reply.
    Could you tell me the procedure to solve this? I don’t know what to do with the Luma Shft and where to find it.
    I’m just starting out in FCP so any help will be great!
  • Joy E reed
    August 27, 2010 at 8:21 pm
    Sure thing, Ravi.
    First, right click on the trouble sequence in your browser & select DUPLICATE. That way if you goof anything up by changing your settings you’ve got the original as a backup.
    Right click on the duplicated sequence and click SETTINGS.
    Click on the Video Processing tab: my guess is that Always Render in RGB is selected. Change it to Render in 8-bit YUV, which should eliminate your Luma Shift problem. Let me know how it goes!
    Peace & respect,
    Joy E. Reed
  • Ravi Kanda
    August 27, 2010 at 8:45 pm
    Hi Joy.
    Everything but ‘Always Render in RGB’is greyed out for me.
    I’ve added a video of what is shown on my system.
    https://www.youtube.com/watch?v=cuLM2PYHlio
    The mov file is located here:
    https://www.sendspace.com/file/rl14qq
  • Ravi Kanda
    August 28, 2010 at 1:30 am
    If the options are greyed out, what would I need to activate?
  • Ravi Kanda
    August 28, 2010 at 1:31 pm
    I’d like to add that this is an animation video I’m trying to add text to. So the compressor setting is set to ‘Animation’
    Could this be the reason for the jump in levels?
    If so, what should I change?
