Activity › Forums › Adobe After Effects › Text Problems
  • Text Problems
    Posted by Faraz Mozafarian on July 21, 2010 at 8:49 pm
    Hello,
    I am editing a project and using after effects to create some titles. I have made sure my comp settings match my sequence settings in FCP and have created some animating text.
    However, When I export and bring the text into FCP it looks distorted, almost as if there are little lines around the text that are moving.
    I tried exporting to a few different codecs, including animation but nothing has worked.
    The text animation looks perfect in AE, it is just when I bring it to FCP that it looks distorted.
    Any ideas on what’s going wrong here?
    Mark Landman replied 16 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Szalapski
    July 21, 2010 at 9:01 pm
    It may be an interlacing issue. Did you check your interlacing settings?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Faraz Mozafarian
    July 21, 2010 at 9:02 pm
    Yes,
    I made sure field render was off. Is there another setting somewhere?
  • Michael Szalapski
    July 21, 2010 at 9:32 pm
    I meant in Final Cut.
    – The Great Szalam
  • Faraz Mozafarian
    July 21, 2010 at 9:44 pm
    Well… my field dominance is set to none. Is that what you mean? is there another setting somewhere in FCP?
  • Michael Szalapski
    July 21, 2010 at 10:16 pm
    I’m not a Final Cut person, so I don’t know. Sorry.
    Do you have a screen shot or an example of the video so we can see what you’re talking about?
    – The Great Szalam
  • Faraz Mozafarian
    July 21, 2010 at 11:43 pm
    I actually did that as well but still no luck. I found a solution by just creating the text in Illustrator and then animating it as a .png file in AE but I shouldn’t have to do that every time.
    Here’s a screen shot of the text in FCP
    https://f1.creativecow.net/916/jagged-text
    Any other ideas of what it may be?
  • Mark Landman
    July 22, 2010 at 1:08 pm
    If the Canvas or Viewer window sizes are set to something other than 100% the scaling can sometimes result in bad artifacts.
    Mark Landman
    PM Productions
    Champaign, IL
