Activity Forums Maxon Cinema 4D text problem -NO text- helllllllp
  • text problem -NO text- helllllllp
    Posted by Darren Fetzer on March 15, 2010 at 4:05 am
    so i’m trying use rosewood STD font in c4d, but when i select that font, there is nothing but an axis. i’ve tried retyping the words in the text/attributes/object but that doesn’t help.
    it worked on the computer at school, but it was using r11.5. i can still open the file and save it, but i can’t use this text. wtf???
    someone please help me. please don’t ignore this message. i really need help.
    Brian Jones replied 16 years, 5 months ago 3 Members · 3 Replies
  • Tim Shetz
    March 15, 2010 at 6:02 am
    Depending on what you are trying to do, you could create the text as outlines in Illustrator (giving you more control over the kerning) and save it as an Illustrator 8 file. Then you could bring it into C4D.
    Tim
  • Darren Fetzer
    March 15, 2010 at 6:39 am
    yea, but then it becomes more difficult to use the extrude nurbs for all the details of the. in fact, it just fills it all in.
    i’ve given up on the problem for the moment, and chose a different font. i’m sure the issue will go away when i get a hold of r11.5
    so i guess the problem is resolved.
    thanks anyway =)
  • Brian Jones
    March 16, 2010 at 1:09 am
    probably you have each letter that came from Illustrator as a group of splines. Select all of one group (all the splines in a letter) and do a Functions/Connect. Toss or hide the group (and remove it from the Extrude) and take the new spline that just got made and put it in the Extrude.
