Activity Forums Apple Final Cut Pro Legacy text problem !!
  • text problem !!
    Posted by Rohan Khokar on February 4, 2007 at 8:40 pm
    hi..im new to FCP…when i am modifying and using my text…i can preview it at full resolution…it looks absolutely crystal clear and non-pixelated….but once i am done with my text and i put it on my timeline, after i render it, the quality is absolutely draft…pixelated to the core….i know this must be a very basic thing but plz help me out …thanx !!!
    Debe replied 19 years, 7 months ago 2 Members · 1 Reply
  • Debe
    February 4, 2007 at 11:20 pm
    Are you judging this quality on the computer screen or on your external video monitor?
    If you are not using an external monitor, it’s possible that your text is fine. It’s your monitoring situation that needs some TLC. The manual has a pretty detailed diagram of how to connect external audio and video monitors. If you don’t have pro monitors available, a TV will do in a pinch.
    If you are monitoring externally, have you checked your render settings?
    debe
