Activity › Forums › Adobe After Effects › Text Presets, Right-to-Left Languages
Posted by Adam Lewen on September 15, 2010 at 4:32 pmHello dear forum!
I am heaving real issues with tweaking the “Word Processor” Text Preset (under Multi-Line) to work with Right-to-Left Languages…
Usually when doing Hebrew with Text Presets, I am able to solve it after tweaking the parameters, but right now I am going a bit insane :). It seem so simple.
If there is someone out there who was able to teak and make it do exactly what it does, but in the other direction, I am seeking for some help here.Thank a bunch!
Adam.
Roland R. kahlenberg replied 14 years, 4 months ago 4 Members · 8 Replies -
John Cuevas
September 15, 2010 at 4:48 pmTry these scripts:
https://aescripts.com/textreverser/
https://aescripts.com/arabictext/
ETA: Sorry, see that the right to left isn’t the problem…
Johnny Cuevas, Editor
http://www.thinkck.com -
September 15, 2010 at 6:23 pmHi Adam, I can you email an AEP with a much better solution (I think). Send me an email to – rork_AT_broadcastGEMs_DOT_com .
Replace the “_AT_” and “_DOT_” with “@” and “.” respectively.
Cheers
RoRKSell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
Adam Lewen
September 18, 2010 at 9:29 pmThanks a lot for the replies.
John, the presets are great but the _ underscore is a tough issue to solve, at least for me.
Roland, your example is simple to execute and can be applied easily over and over.Thank!
September 19, 2010 at 6:23 amI’m glad it’s worked out for you Adam. I’ll be posting download links to this AEP with additional comps at https://www.facebook.com.broadcastGEMs before the end of next week.
FWIW, what I sent you was a modification (changing the appearance of text characters to appear from Right to Left) of an AEP found in my product, broadcastGEMs AE Pro Series Volume set of AE templates.
Happy New year!
RoRK
AE Training in South East Asia. AE templates for sale and rental. Click here for more
Ahmad Wadiei
May 6, 2012 at 8:43 amDear Roland
May you please help me with same problem.
I want to change the order of text preset for right to left language in After effects for multiple text line.Thanks in advance
May 7, 2012 at 1:51 amDownload Link to WordProcessor – Right-to-Left Preset
Hi Ahmad, the solution I have works ideally with the Word Processor preset. You will also need to read the following rather simple instructions to get going.
The AEP uses Expressions and works quite well and is sufficiently robust to handle any text length and font pitch. You will need two keyframes in the positin property.
I have provided two compositions to set you on the right track –
1) bGEMs R2L TexT – Example
2) bGEMs R2L TexT – TryoutFirst, take a look at composition “bGEMs R2L TexT – Example”.
1) Select both layers and hit the “U” key to view their keyframes and Expressions. You won’t have to do any Expression scripting. So, pay attention only to the Cursor layer and its Sensitivity and Position properties. Sensitivity is an Expression Slider Control used to tweak the cursor’s position. However, it can be disregarded most of the time.For now, drag the Timeline Indicator along the area of the Timeline where the keyframes exist just to get a feel for what’s happening. Next, you now have to appreciate that the Expression in the Text Layer takes the x-Position values of the Cursor Layer to write on each text character.
What is important for this to work is to ensure that the X position values for the two Cursor keyframes correspond to the actual left and right margins of the text string. YOu can use Guide Markers in the Comp Panel to guide you where to place the (x) position values for the start and end points of the cursor.
Now go to the composition bGEMs “R2L TexT – Tryout”. To take things for a spin. Again, ensure that you can see all the keyframes for the Cursor layer. In this composition, I have deleted the keyframes for Sensitivity. There are two position keyframes. The Expression requires 2 keyframes for it to work. More or less will not do.
ALl you need to do now is to –
1) Move the Timeline Indicator to the 4 second mark.
2) Double click the text layer in the Timeline and then type in your text
3) Now perform a RAM Preview
4) You should notice that things are not working as well as they should.
5) The trick is to ensure that the X position keyframes are similar to the right and left margins of your text. To do this, move to the 4-second mark and then move your cursor below the left and right margins of the text string and take note of these numbers.
6) Then ensure that the first keyframe’s X position value corresponds to the text string’s Right Margin. For the second keyframe, ensure that the Cursor Layer’s X position corresponds to the Text String’s Left Margin.
7) Now RAM Preview
8) Use the Sensitivity Slider property to tweak when the characters appear.The effect works well when the cursor is slightly ahead of the appearance of the next text character. The Sensitivity Slider helps in this case.
Unfortunately, you cannot have more that 2 keyframes in the Cursor’s position parameter or have more than a single line in the text string (use multiple instances to accomplish this). I’m not a programmer so I am not able to fix these issues as of yet, especially the last one which is tricky and any solution may involve more trouble than it’s worth. Just duplicate the comp and repeat and then nest them into another comp.
The beauty of this mechanism is that you can use any graphic as the Cursor Layer to create a more visually interesting type-on effect.
HTH
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Ahmad Wadiei
May 7, 2012 at 8:02 amDear Roland
Thank you very much for your help. It is very helpful and I’m going to find out with other effects.
It works also for multiple lines just it runs from bottom to top instead of up to down, is there a way to correct it??
Please let me know if I can appreciate you with your products.Thanks again
May 7, 2012 at 2:51 pmHi Ahmad, you will need to nest each line into its own composition when working with multiple lines. This issue was laid out earlier.
I forgot to mention in my last post to point folks to this link – https://aescripts.com/arabictext/. I have not used it so I can’t vouch for its efficacy but it’s worth a look.
Cheers
