Activity › Forums › VEGAS Pro › text position in preview window vs. render
  • text position in preview window vs. render
    Posted by Lily Ching on April 27, 2009 at 4:48 pm
    Hello there
    The text position on my preview and my rendered output are different-why’s that?
    I’m currently set my project as HDV 1080-50i (1440×1080, 25.000 fps), the preview is 360x270x32, the display is 480x270x32.
    My render setting is VCD Pal (Mpeg1), 25fps,1440 x 1080.
    The “text” on the output is always in a much higher position than as what is in preview window- and inevitably it has blocked the important scene that in the video.
    Could anyone tell me how should I get the position of the text
    as the same as the output?
    Lily Ching replied 17 years, 5 months ago 3 Members · 5 Replies
  • John Rofrano
    April 27, 2009 at 6:25 pm
    Did you really mean VCD PAL MPEG-1? Why?? You are going from HD 16:9 widescreen to VCD which is less than 4:3… it’s almost square. Your problem is that you are judging placement on a project that bears no resemblance to the aspect of your final output. Set your project properties to match your output and there will be no surprises.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Lily Ching
    April 28, 2009 at 7:23 am
    What is the best output format that I should use for HD 16:9 widescreen then?
    Please advise.
    Thanks.
  • Enrique Orozco
    April 28, 2009 at 3:17 pm
    … Bluray file…
    good luck
    Enrique Orozco R.
    iDEA DigitalVideoStudio
  • John Rofrano
    April 28, 2009 at 4:30 pm
    That depends on how you plan to deliver it. Web? PC? DVD? Blu-ray? If you are just saving your project as a file and your source is HDV I would render to HDV using the MainConcept MPEG-2 type and one of the HDV templates. If your delivery target is Blu-ray then use one of the Blu-ray templates.
    ~jr
  • Lily Ching
    May 5, 2009 at 7:56 am
    What would be the best format if it would be delivered by DVD?
    Can I still use MPEG2?
